Results 1 to 15 of 18
Thread: I noticed my power steering fluid leak...
    My son is a mechanic & he said to use the DEXRON-III Automatic Transmission Fluid. From what I understand, the fluids are essentially the same but the ATF may have some harsher detergents in it. It could actually make the leak worse.
    I'd probably schlep some LUCAS in it for a while to see if that helps with the leak. I've run it before without any problems (not in the VX though).
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    That was the first thing I tried. As you can see, it didn't quite work out
  1. Power steering fluid leak!
    By jdm monkey in forum VX Troubleshooting...
    Last Post: 10/19/2012, 06:52 AM
  2. Leaking Power Steering Fluid
    Last Post: 11/10/2008, 05:50 AM
  3. Power Steering leak
    By Dino in forum VX Troubleshooting...
    Last Post: 10/25/2007, 03:43 PM
  4. Power Steering Fluid
    Last Post: 09/05/2006, 10:02 AM
  5. Brake Fluid vs. Power Steering Fluid
    By TEN36VX in forum VX Troubleshooting...
    Last Post: 07/01/2006, 03:12 PM
