My Tridon EP34 Flasher came in the mail, yesterday. This morning (before dawn to beat our triple digit heat), spent near 2 hours trying to find something resembling:
Even removed the section of dash cover under the steering column, above the brake and gas pedals, to try to get a better view above/behind/left of the fuse box. Wonder if the '99 Ironman uses some different kind of relay/flasher module?
Behind the fuse box I found 2 black plastic modules with bundles of wires plugged into them. They are about 2 or 3 times wider than the relay/flasher in the photo.
Any photos of a VX relay/flasher plugged in under the dash? Seeing that sure would help pin point the relay/flasher. TIA.
