Results 1 to 15 of 20
Thread: New product from Klearz...maybe
    The team at Klearz is willing to make rear side marker lenses for our VXs.
    What they need is a set of lenses for a few weeks to make molds.
    I'm willing to send mine, but I'll have to take them off of my VX to do so.
    Does anyone have an extra set that could be used for this purpose?
    You'll get them back in a few weeks after they make the molds.
    I really like the look of Ron's VX with the clear rear marker lenses but they were a lot of work. This would make it easy for those that want something different.
    Thanks for the help if you can.
    Jan 2006
    I may have a spare set. I'd have to check when I get home. Do you know if they guarantee that you would receive the originals back undamaged after they make the molds? Time frame?
    Apr 2011
    1999 Astral 0074, 2001 Proton, 1999 Ebony, 1999 Astral 0163
    I also have a spare set! If Knigh7s changes mind, I can donate. But I need them back! So there definitely needs a promise of return undamaged.
    "Cast away the unessential to find the essence..."
    Here is the note from Tina and the address:
    Hi,
    Yes the lenses will be returned, in better shape usually then when we receive it.
    We will sand all the writing on the surface, if there is any, and then buff the lens to a mirror finish before making molds.
    Is it possible to confirm if the lenses/housings are same left to right? I confirmed to her that left/right are different
    We will probably need a month or 2 before returning the lenses since we are so busy right now.
    Thanks
    Tina
    Klearz.com
    Ship to Canada:
    Jason Rhodes
    3 rue de montmagny
    Cantley QC
    J8V 3J1
    Jan 2006
    @VXobsession, if you have yours on hand, you are more than welcome to send them out. I still have to check if I have at home of if I put them in storage. Let me know if you decide not to send yours and I'll go ahead and hunt mine down.
    Apr 2011
    Mine is right outside my shop door I'll pull them tomorrow. We ARE talking about the rear fender reflectors, right? By the back wheel?
    Quote Originally Posted by VXobsession View Post
    Yes, the lights behind the rear tires on both side that illuminate with the lights.
    Their Email address is:
    info@klearz.com
    I would Email and let her know that they are coming so she can watch for them.
    '01 Ironman #1109
    If a set does not get sent for some reason, I may have mine in my garage I can send to Jason. He and I have been working together for several years for another vehicle. So, if anything, I can help expedite this product to fruition. Just let me know about the lenses and I can send directly. rudy
    www.aftershockproducts.com
    Or.... a spare set of rear lenses from a Miata will work.
    (those have been the long time perfect fit assembly for the VX)
    Important
    New note from Tina...I would say this is a deal killer for me unless Ron has some pull.
    Something i forgot to mention, if the lenses are on housings, and they don't detach easily, we might not be able to return the OEM in good usable condition, as well if the lenses are cemented on, we might need 2 sets to make our molds.
    Thanks
    Tina
    Klearz.com
    What year?
    I know that Ron used the front assembly for his clear rear lenses, but they required quite a bit of modification.
    '01 Ironman #1109
    Let me find my rear lenses in my garage and review it. Not sure whether I used the oem housing and added the modified miata lenses or just used the miata housings too. I'll chat with Jason about this. If oem lenses have to be sacrificed in order to make molds for production, then I'll volunteer mine. I'll post results later.
    FYI, the miata lenses will work with the vx housings. The internal housings just need to be trimmed in order to sit flushed with the housing. However, if you look from the side, you'll see that the lenses slightly bow out past the center about an 1/8" past the housing. Not really noticeable from a couple of feet away. But if you prefer that perfect oem fit, then getting molds made would be the ticket.
    Thanks Ron.
    Apr 2014
    1999 Dragon Green Mica VX
    Once they are made, I would love to buy a set. How/Where would that be?
  1. Klearz lenses with flakes added to resin
    By tysamigo in forum VX Modifications...
    Last Post: 08/28/2015, 05:37 PM
  2. Clear lenses from Klearz (Installed)
    Last Post: 09/14/2010, 11:37 PM
  3. kLEARZ . COM ???
    By johnny010 in forum VX Modifications...
    Last Post: 05/14/2009, 08:58 AM
  4. Klearz Email received.
    By VXNIT in forum VX Talk...
    Last Post: 12/17/2007, 12:27 PM
  5. Lenses From Klearz
    By navistar in forum VX Modifications...
    Last Post: 12/13/2007, 03:36 PM
