Here are the pics in my gallery:
http://www.vehicross.info/gallery/sh...php?photo=2958
http://www.vehicross.info/gallery/sh...php?photo=2959
http://www.vehicross.info/gallery/sh...php?photo=2960
Ok, a few notes on the gauges:
I bought two kits, one for a '94-'95 Trooper, and one for a '99-'02 Trooper off eBay, total with shipping, around $70. The '94 kit has the speedo, tach, and turn signal area that match; the '99 kit has the gas gauge, TOD, and shift indicator areas that match. There were, however, some problems:
1) The TOD on the Trooper is just slightly a different size, so the TOD didn't match up. I'm trying to find a used TOD guage or I may relocate this gauge to the fuzzy hole area and install oil pressure and volt guages from a '94 Trooper cluster I have - looks like they'll screw right in and then I'l have to run wiring.
2) The gas guage I need is attached to the speedo I don't need. Don't know why they did that - the '94 kit has all pieces separate. So, right now, my temp guage has an oil pressure front on it! As I said above, trying to decide what to do with the gauges before I cut the '02 to fit. One problem with cutting the '02 version is that it contains a printed circuit under clear plastic which powers the lights - not sure if I could patch that after cutting??
3) The shift indicator takes a lot of trimming to make it fit - but it does
BEFORE you buy the Axiom knob (if you like it!) be aware that it is not a direct bolt on, I had to do a lot of modding to the mechanism, and still have a little more to do to get it down flush with the cover plate. Ahhh, a labor of love!![]()
