Results 1 to 4 of 4
Thread: So my Ron Davis rad has sprung a leak
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    I was running errands today, and when I got out of the truck, I caught a whiff of antifreeze. Looking under the truck, I could see some water, so after I finished my errand, I high-tailed it home. The engine bay was *soaked*, but the truck never overheated. I couldn't tell where the leak was coming from, I just was praying it wasn't the water pump, one of the head gaskets, or the block. Since so much coolant had leaked out, I removed the radiator cap, and a fine spray started coming from the core. The hole is on the engine-facing side of the radiator, and there's no puncture hole on the front side that I can see, as that area is covered by cladding.
    I called up RD, and they said they don't do repair, but they told me to find a place that does industrial radiator repair. I found a place not too far away, called 'em up, and they said they could repair it, but they aren't open tomorrow. So, looks like I'll be dropping it off Monday morning @ 8, as it's a tad bit hot under the hood right now and I don't feel burning myself. Yay.
    Did you use any additives like Purple Ice or other stuff that says it helps coolant run a few degrees cooler?
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Nopers. It looks like there was some distress where the leak crack was, but I can't figure out how it got there. Nothing to do about it now except pay for the repair.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Fixed. $123, and I pick it up tomorrow.
  1. Oil pan leak
    Last Post: 09/11/2014, 04:34 PM
  2. Need help with oil leak
    Last Post: 06/10/2013, 05:42 AM
  3. serious oil leak
    Last Post: 10/05/2010, 08:37 PM
  4. Oil leak from ????
    Last Post: 11/03/2008, 11:16 AM
  5. Oil Leak on New 99 VX
    By Jonnie in forum VX Troubleshooting...
    Last Post: 08/03/2003, 04:20 PM
