Results 1 to 12 of 12
Thread: Can anyone diagnose my issue just by hearing it?
    Nov 2010
    2001, White, Ironman
    https://www.youtube.com/watch?v=hTAyxJjyc4s
    I purchased my new vehicross a few days ago knowing that it had this engine noise. Got a really good price on it.
    Can anyone diagnose the issue? I am hoping that it is just a minor issue with one of the valve springs or something - i havent dug into the engine yet. But if i need to replace it or rebuild it im not too bummed.. just hoping i dont have to.
    Thanks,
    Apr 2011
    1999 Astral 0074, 2001 Proton, 1999 Ebony, 1999 Astral 0163
    Does it seem to be driving fine? I'm gonna have my husband watch this vid...he's built a lot of these engines...I'll be back in a few.
    "Cast away the unessential to find the essence..."
    Nov 2010
    Quote Originally Posted by VXobsession View Post
    I have only driven it around the driveway a little bit. seemed to work fine
    If general consensus is that its a rebuild fix ill probably just buy a new long block and then drive this engine till death.
    Could be as simple as a shot Serp belt tensioner..
    ...or even a bent fan blade rubbing.
    Hope so..cause thats an easy fix .
    Jo
    Apr 2011
    HOPEFULLY it's something else.......BBBUUUUTTTTT
    ...my professional said it REALLY REALLY sounds like you've got a rod knocking, piston hitting the head...etc. Something of that nature....
    Basically, it's broken
    Somebody obviously didn't give it enough oil to quench it's ravenous thirst....
    But like I said, HOPEFULLY it's something else.
    Nov 2010
    Ah yea bummer thats what i was thinking it was but wanted to hear someone elses input. Fingers still crossed thats not the case tho! haha Thanks
    Marc may well be right....
    And if it is Rod knock / piston hitting head..
    ..you can isolate to a degree with the old
    screw driver stethoscope trick.
    BUT.. I do encourage you to check tensioner.
    This click has been seen here before...
    ...and tensioner was the culprit.
    I'm assuming click gets faster as you rev?
    Jo
    Nov 2010
    Jo
    You assume correctly!
    I will definitely check everything i can before diving into taking the engine out. Its not too difficult but id rather avoid it if i can.
    Thanks for the tips!
    Oct 2009
    2001, Proton, 0617
    sounds like a tensioner, just replaced mine last week
    '99, White, Iron-Man (0109)
    An quick and easy way to check to see if it's a rod knocking is to systematically disconnect (unplug the 2 wire connector) one coil pack at a time. Rev it and listen. If there isn't any change, then plug it back in and try the next one. That's how my VX currently sounds and the problem is with cylinder #1.
    Jul 2013
    01,Victory White Ironman #0549
    I had a similar noise happen to me. Check your coil packs and spark plugs.
    Turned out I had a coil boot fail, and spark plug was broken in half. Replaced the coil pack and did a compression test. Runs like a champ now.
    Hoping for the best.
    May 2014
    2001 Keiser 0656
    I've had a similar sound on another older car before the rod shattered and went through the cylinder block. Was rod knock from a bent rod.
    Rod knock in this case is one possibility. Could also be a bent valve and/or broken spring.
    Isolate the source of the sound, via stethoscope/screwdriver/etc. If its engine related do a dry and wet compression test. That will tell you if its head or block related. Rebuilding a head is a lot less work than swapping out an engine.
    T.
  1. VX Died Today, Lets all diagnose!!
    By UWVX89 in forum VX Troubleshooting...
    Last Post: 08/06/2013, 08:08 AM
  2. TOD issue... maybe!
    By 99_VX in forum VX Troubleshooting...
    Last Post: 02/22/2012, 04:22 PM
  3. uh oh, First issue with VX
    By H3_VX in forum VX Troubleshooting...
    Last Post: 08/16/2011, 02:39 PM
  4. AC not working.... how to diagnose?
    By cyan328 in forum VX Troubleshooting...
    Last Post: 07/21/2008, 07:49 PM
  5. Diagnose Engine Failure??
    By VX_PA in forum VX Talk...
    Last Post: 11/19/2003, 09:50 AM
