For my Birthday, the fambly got me OME 913's for the 99 Amigo. While the springs are the same as those for the VX, there is some differences on the rear suspension. It was a bit more difficult to install the springs on the Amigo than for the VX (rear suspension just wouldn't droop enough for removal of the spring). Some redneck engineering got'r done though. A bottle jack between the axle & the frame forced the droop needed (didn't figger that one out though until several PITA bolts were removed that didn't need to be).
The front suspension on the other hand appears to be identical to the VX though ('cept for the shocks of course). The Torsion Bar crank for lift was almost too easy after the battle with the rear springs (kinda anti-climatic).
The point of this thread though is to indicate that if you need front suspension parts for the VX, look for a 99 Amigo in the boneyard. The rear suspension is a different matter though ... nothing on the rear end will be of use.
