Results 1 to 9 of 9
Thread: can anyone tell me if this is the correct part?
    Mar 2014
    2001, Yellow, 1336
    I need to replace the driver side CV axle..... STILL!!!!
    I found this one and believe it is the correct one, but need to confirm that with someone that knows for sure. I don't need the whole axle just the CV joint.
    http://www.cardone.com/Products/Prod...661349S&p=rock
    '01 Ebony #0939
    I got the same result on www.rockauto.com that carries Cardone products...for what that's worth.
    Take a look at this thread....
    www.vehicross.info/forums/showthread.php?t=24109
    OEM specs on races and cages.
    Many using them now including me...
    ...no issues...even after brutal off roading.
    I'd highly recommend them.
    Mar 2014
    2001, Yellow, 1336
    ok, I am going to order the one off of amazon (SurTrack IZ-8021) ........ I hope that it fits... the last time I bought both complete axles and they where to short. That was very frustrating and a waste of money.
    Yup...
    Quote Originally Posted by VehiTONY View Post
    ...they fit.
    As per the many posts in that link from those that have used them...!!
    Jo
    Mar 2014
    2001, Yellow, 1336
    I know, I know....... Just already dropped $200 and got nowhere. My bad.
    No problem
    Wasnt sure you'd read the reports from others.
    After you remove OEM axle, be sure you thoroughly
    inspect / clean and re-grease the 'green cup' before
    fitting the new 1/2 shaft .
    Jo
    IMHO, Excellent example of how this site MORE than pays you back for a $20 donation!! The CV axle, joint, 1/2 shaft etc.....very tricky info and discussed here extensively. Could have saved him 10-fold!
    Yeah, could have gotten same info w/o donation, but some day this site may not be here to help you out.....
    Mar 2014
    2001, Yellow, 1336
    Ya, I pretty much figured that to be common sense to clean and regrease the cups. -- Thanks
  1. CV Boot Replacement Plan - Correct me where I am wrong
    Last Post: 05/06/2014, 12:39 PM
  2. Correct storage bin p/n to replace changer?
    By Tone in forum VX Modifications...
    Last Post: 03/14/2005, 04:24 PM
  3. I need a part #
    Last Post: 01/15/2005, 09:51 PM
  4. part #
    Last Post: 04/04/2004, 07:09 PM
  5. Where does this part go?
    By Grant Eaton in forum VX Troubleshooting...
    Last Post: 03/16/2003, 01:59 PM
