Results 1 to 15 of 24
Thread: Burnt out window motor
    Mar 2003
    1998 Blue standard 1198
    Took the VX to an auto electrician today and they managed to get the passenger side (left for a JDM) working but concluded that the switch on the door arm rest must be cooked as well. I may be wrong but I'm guessing that the USA based cars have a different unit but just in case does anyone have a photo of the drivers side window switch assembly. It's a long shot as I read 2 door RHD on the back.
    2001, Dragon Green, 1342
    oi mate, here is a photo of the US spec passenger side, RH window switch in the door handle, hope that helps.
    If you can get your hands on the US one, you can pop it out to use on your offside door I think, maybe
    Mar 2003
    Thanks for that, it won't be suitable so I guess I'll have to source a proper RHD unit.
    Quote Originally Posted by David Wiltshire View Post
    I meant the cream colored switch box that is attached to the black handle. It's not the same as your JDM?
    Mar 2003
    I don't think the position of the single lock switch ahead of of the two window switches would be in the correct position. Thinking about it I may be able to blank off the lock switch altogether can't see it's much use.
    On the back of the ivory coloured block it does say RHD so anything else may not be correct.
    Feb 2010
    1999 Ironman,#1-1767, #2-1326
    Wonder if you could use our drivers side and just have the switches be not correct left to right. The window (driver and passenger side) part would be on the wrong side.
    Mar 2003
    Quote Originally Posted by yellowgizmo99 View Post
    I thought that as I could disable the lock button. Anyone know where the best place is for a window motor and window switch nowadays?
    I think I have a used motor ... but I don't have any switches.
    Mar 2003
    Thanks Tom I would be happy to buy it off you, has anyone removed the motor and tried to get it re-furbished or is that a waste of time. If new motor supplies become limited is it worth looking into an alternative?
    Do St Charles Isuzu still carry all of the parts still? I know Merlin was a great help when I phoned up years ago but do they still have an active working parts department for the VX?
    I'll dig it out tomorrow. Which side do you need (Left or Right).
    There should be places that could rebuild the electric motor but it's probably not cost effective. I'm guessing that the motor is probably the same as on other Isuzus even though the regulator is different.
    I'll see if there are any idenitfying #s on the motor when I pull it off of the regulator.
    I'm thinking that our major problem is the regulator & possibly the upstream electrics so finding an alternative to the OEM motor probably isn't worth too much effort.
    I'm not clear David.....are you after the beige electronic module that's attached to the black switches, OR are you after the actual motor for the WINDOW? Or both?
    Here's closeup pics of the window motor attached to the window regulator. It's super easy to remove the motor, it's just those 3 brass colored screws.
    In case somebody is looking for used WINDOW MOTORS, here's BOTH ON EBAY for a VERY reasonable price!
    LEFT SIDE (US Driver side)
    http://www.ebay.com/itm/ISUZU-VEHICR...E:B:SS:US:1123
    RIGHT SIDE (US Passenger side)
    Here's close up pics of the US spec window button modules, in case it helps you decide if you can mod it to work for you.
    2001, Proton Yellow, #0580
    Merlin went to work for Tesla so he's no longer at St Charles - also the Isuzu parts section is no longer available online for St Charles so I'm not sure if they're still offering Isuzu parts. Still worth a call I think. About the motor - I believe you can just replace that part of the unit but I'm not sure.
    Apr 2006
    '99 Copper Orange Mica 1499
    I called St Charles looking for U Joints a few weeks ago. They are no longer carrying any Isuzu parts. I sourced them from Scarff Isuzu in Washington at http://www.partswebsite.com/isuzuparts/
    VX: What your Murano dreams it could be...
    Mar 2003
    Quote Originally Posted by WyldWeasel View Post
    Thanks for that I've just sent an enquiry asking if they ship to the UK.
    Mar 2003
    Thanks Sue,
    The USA models seem to be completely different to the JDM, a friend of mine who is into electronics has offered to take mine apart and see what he can do.
  1. P. Side window motor
    By FenderBender in forum VX Talk...
    Last Post: 04/05/2012, 07:17 PM
  2. Window Motor or Switch?
    By jmassa in forum VX Troubleshooting...
    Last Post: 11/07/2011, 08:03 PM
  3. Window Motor
    By Joe Izusu in forum General Tips...
    Last Post: 01/12/2009, 07:53 PM
  4. Window Motor price???....
    By Thejerseyfish in forum VX Troubleshooting...
    Last Post: 01/23/2006, 01:32 PM
  5. Window Motor....
    Last Post: 01/14/2006, 01:59 PM
