I was hoping someone could shoot me some advice. I have an LED License Plate Holder that scrolls words. It's something like this:
http://www.kleargear.com/1904.html?u...vsfhu=31393034
It's not exactly the same, but close enough.
It has 3 wires:
Black = Ground
Red = +12VDC
Blue = per the manual you have one of 2 choices:
(1) SPST Toggle to +12VDC. This will operate the plate only when the switch is on
(2) Tie the RED and BLUE together and instead of running to +12VDC, run it to brake lights. This will operate the led plate when the brake lights are on.
I wanted to do a 3rd option but don't know quite how to wire it. I feel like it's a simple solution, but I just can't figure it out...
I wanted to have a toggle switch (I think SPST, not sure though) so that when it's switched to position 1, the led plate will illuminate. When it's switched to position 2 it will ONLY illuminate when the brake lights are depressed. This way if I see a cop, I can switch it to "legal" so that it's only on with the brakes.
How do I do this, and what kind of switch would I need?
