Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
Thread: Wheel offset
    A man of to-many words Tom
    Apr 2011
    1999, Astral silver, VX, 1575
    I just want to clarify, the wheel in question appears sucked in and I want it to stick out like the other tires not the other way around. Tom, I'll do as you suggested in regards to the ball joint flip. If that doesn't work I'll try the fender/cladding option. Thanks to everyone's input and advice.
    "Remember Tonight... For It is the Beginning of Always." - Dante Alighieri
    Ball joint flip will not help with width problem.
    Apr 2011
    Hmm. I guess I won't try the ball joint flip. Should I just remove the lift kit, reset everything back to stock and re lift and realign?
    Personally what I would do is check your ball joints to insure they are the same on both sides. Just measure them. If those are the same then its a body panel issue (unless the vx was wrecked and the frame tweeked).
  1. wheel advice offset/backspacing
    By djvx in forum VX Talk...
    Last Post: 06/12/2010, 08:04 AM
  2. Wheel Offset Calculation Help
    Last Post: 01/25/2009, 09:34 AM
  3. Offset
    By CrnCnn in forum VX Modifications...
    Last Post: 03/20/2007, 06:51 PM
  4. What's an offset?
    By Medman in forum VX Talk...
    Last Post: 06/26/2004, 07:17 PM
  5. Wheel Offset downside??
    By omegavx in forum VX Modifications...
    Last Post: 06/17/2004, 08:45 PM
