Results 16 to 30 of 35
Thread: Wheel offset
    Apr 2011
    1999, Astral silver, VX, 1575
    Bump
    "Remember Tonight... For It is the Beginning of Always." - Dante Alighieri
    '01 Ebony #0939
    Is it possible you've lost your camber shims on the upper control arm? Given the way you've described the position of the wheel/tire assembly changing from time to time (when it was put on a lift then lowered, after you've driven it), maybe you have some play around the upper control arm fulcrum pin?
    Apr 2011
    Wouldn't that cause an uneven ride? I was told that all of the wheels are centered so the wear on the tires are relatively equal.
    '01 Ebony #0939
    Quote Originally Posted by Intrepid_Vanguard View Post
    I'm not really sure WHAT results it would have. If the shims were gone, it seems like there would be some play not normally there and a person would likely hear something knocking back and forth when making direction changes.
    I'm simply trying to guess what could be causing that tire to at some times look normal and at some times look like it's sticking out farther than the other side as you've described.
    On a front wheel drive car I have, I seem to recall c-clip retainers having to be used when installing the cv-joints. Maybe the one on your passenger side has come off?
    I still think it is just a body panel alignment issue since you have no other symthoms. The VX was hand assembled and since ceramic dyes were used parts are all just a bit different.
    Apr 2011
    I haven't noticed any clicking, clacking or wobbling. The ride is smooth. When I say that the wheel looks like it 'evens out' is when that wheel is on the slightly higher end of uneven ground which makes it look normal for some reason. And is there a way of checking straightness of the body panel alignment? I was thinking that the cladding might have been molded differently on that wheel but it measures roughly the same dimensions as the driver side.
    Another possibility is if you had ball joints replaced on one side and not the other. Some of the aftermarket bj's are wider.
    Apr 2011
    Would that create an inch difference?
    It could.
    2000, Ebony, VX, 0370
    Thanked: 12
    Haven't read through the whole thread so this may have been suggested already, but are you sure both of your front torsion bars are indexed the same? Did someone start to do a lift on it and then just stop after doing one side?
    Apr 2011
    A buddy of mine was thinking the same thing, but wouldn't the torsion create a difference in the wheel coming towards the center instead of the wheel being sucked in?
    The torsion bars would/could cause a height difference. All Caster/Camber/Tow-in is corrected for after the torsion bar crank.
    You could do the ball joint flip & see if that allows the alignment shop to get it into alignment & adjust something to push the wheel inboard.
    I'm being vague since I really don't think that there is an adjustment for that.
    If your ride is good & your alignment is spot on, I'd strongly suggest to try & shim the fender and/or cladding to get the aesthetics to your liking.
    '01 Ebony #0939
    Depends on which way the torsion bar had been adjusted...if it was. If the torsion bars were indexed unevenly, and an alignment was done afterwards, your wheels may be aligned properly, but they wouldn't necessarily look the same in relation to the body.
    But that is why alignments are ALWAYS recommended after lowering/lifting.
    T bars would not cause a width difference, only height.
    what it said ... just less words
  1. wheel advice offset/backspacing
    By djvx in forum VX Talk...
    Last Post: 06/12/2010, 08:04 AM
  2. Wheel Offset Calculation Help
    Last Post: 01/25/2009, 09:34 AM
  3. Offset
    By CrnCnn in forum VX Modifications...
    Last Post: 03/20/2007, 06:51 PM
  4. What's an offset?
    By Medman in forum VX Talk...
    Last Post: 06/26/2004, 07:17 PM
  5. Wheel Offset downside??
    By omegavx in forum VX Modifications...
    Last Post: 06/17/2004, 08:45 PM
