Results 1 to 8 of 8
Thread: e-brake light on dash
    '01 Ironman
    Well for the past 2 days my ebrake light is flashing on and off depending on how I use my brakes. I see the brake fluid resivoir is on fill, is this all it is? Just add brake fluid? Or is it actually my e-brake somewhat stuck? The reason I ask is that its been in the negative temps for the last week and I know e-brakes can get stuck, when cold. Just looking for confirmation really, pretty sure I'm right, and a search didn't pull up anything.
    Oct 2003
    2000 ebony 0622
    My daughter drives an Explorer that had the same symptoms. She set and released the ebrake several times but light still went on occasionaly. Since she lives out of town, I called a mechanic friend. He said the brake fluid was probably low...just check it and fill it since it is on the same system as the parking brake. She did check her fluid and it was low. She bought a $2.00 pint of dot 3 fluid, topped it off and everything was fine.
    Hope this helps.
    AlaskaVX, i had the same problem with my Mistubishi Eclipse. The E-Brake light would stay on if it was very cold out. It could be a frozen contact or something.
    98 mica yellow 0086
    Probably your brakepads...
    2002, Grey, Axiom, 7578
    I would definitely have it checked out. Our 1995 Mitsubishi Montero brake light came on after we had our car stereo installed by Car Toys. We thought it was just a disconnected sensor or something. The brakes started failing three days later and we barely made it to the shop. Turns out our Master Cylinder went out.
    I would strongly suggest you have it checked out. Most shops will do a free estimate.
    Brent
    www.xanderstudios.com
    Oct 2003
    99', Astral Silver, 0430
    E-Brake light in the cluster comes on when you are low on fluid. I have noticed this after each brake pad change on mine. Just fill that thing up!!!
    Fixed yet?
    '01 Ironman
    Put some brake fluid in 2 days ago and have not seen the light since.
  1. dash light mods
    Last Post: 12/15/2017, 09:30 PM
  2. Oil dash light
    By Pepino in forum VX Troubleshooting...
    Last Post: 01/28/2008, 05:09 PM
  3. alarm light dash LED
    By RicksVX in forum VX Troubleshooting...
    Last Post: 07/09/2006, 09:02 PM
  4. Brake indicator on Dash
    By ScottinMA in forum VX Troubleshooting...
    Last Post: 01/28/2006, 12:32 PM
  5. Dash Light outage
    By SPAZZ in forum VX Troubleshooting...
    Last Post: 12/31/2004, 01:28 AM
