Results 1 to 9 of 9
Thread: Shock Question OME or Rancho
    Mar 2011
    1999, Astral
    I will be upgrading my shocks in the next couple of months and the question is, Rancho RS9000XL or the OME Nitrocharger shocks. I already have OME 919's to even out the weight of the roof tent and overland gear. My stock shocks are fine in function but after driving a Dodge 3500 after adding new shocks I believe they could be the answer to my stiff ***** suspension and bumpy ***** ride notwithstanding the heavy weight springs of course.
    Vote and give me your knowledge...
    I have the OME on mine & love them. I primarily went with them since I know that I'd never use the adjustment feature of the Rancho's.
    Nov 2012
    I find the ride with the RS9000s noticeably plusher than the stock ones.
    There's no 'I' in denial.
    Nov 2007
    1997 SILVER
    I personally think both of the brands mentioned would be a "down grade", not upgrade.
    But then, I like my suspension stiff so I can out-corner the turbo'd rice burners.
    Guess I just never growed up.
    PK
    Mar 2011
    1999, Astral
    I think I will go with the OME and tell you guys the results in a couple months, for extended travel on and off dirt (no crawling) I need to do a couple other upgrades
    Jun 2014
    99, silver, vehicross
    Did you change the springs or ride height when you did you shocks?
    disasterlady Guest
    So how did those OME shocks work out?
    Anyone: What model and where did you get the OME Nitros?
    Also are there any special instructions on swapping out the shocks on a VX?
    I'm also wondering which to get and would really like to have a plusher ride?
    PLEASE???
    thanks, Julie
    01, LineX tan/black, 1055
    They are easy to change, do it yourself with some jacks and jackstands, no special tools needed, or any shop should do it fairly cheap.
    I can't see not getting the ranchos, as they are adjustable and can be tuned to your preference, but if you don't likethe OME shocks, you are SOL. I do a lot of wheeling, so I am adjusting them from stiff to soft fairly often.
    Mar 2011
    1999, Astral
    I work in Alaska from Feb-Sept so I haven't been able to do any work on the VX in AZ, just ordering parts to wait for me when I get back before the Big Trip to the East Coast.
  1. Rancho RS9000XL shock install
    By vxcp in forum VX Troubleshooting...
    Last Post: 05/18/2016, 02:33 PM
  2. Shock absorbers Rancho 9000's?
    By David Wiltshire in forum VX Talk...
    Last Post: 08/12/2013, 06:37 AM
  3. Shock Extenders or Rancho 9000's?
    By GPA in forum VX Modifications...
    Last Post: 08/09/2013, 07:27 PM
  4. Rancho shock question
    By Daly in forum VX Modifications...
    Last Post: 07/06/2011, 08:40 PM
  5. Rancho 9000 shock question
    By AndyC in forum VX Troubleshooting...
    Last Post: 12/21/2005, 12:25 PM
