Ever since the small accident in 2010, the horn would stay on constant so I removed the relay until I could get it looked at. I took it to a reputable service center and they said...
customer states horn is not working since accident,check & advise
Labor To Diagnose Problem
*** Installed Horn Fuse And Noted Horn Contacts Sticking In Steering Wheel. Removed Drivers Side Air Bag To Inspect Powers And Grounds And Noted Soft Spot In Assembly. Will Need To Replace The Steering Wheel Air Bag As The Horn Contacts Are Inside Of The Air Bag Assembly.
I want to know... is there any truth to this? Does anyone know?
