OK, so I believe I have found the source of many problems. I have just purchased me VX a week ago and found that the TOD system didn't work and had the check light flashing. So i took it for another test run in some sand (in 4L) and could hear clicking from under the VX while going slowly straight. Then more prominent while turning sharply all the way only..... So I checked the CV's when I got home and found at first glance the boots looked good, but where both split in the grooves.
So the question is should I replace the CV axles or are they salvageable? Can I just clean them, repack grease, and just replace the boots?... Also, is it hard to do? Any special tools?
Thanks for any help!
