Thanks
Will give it a shot once temperature warms up.
Thanks
Hi,
I am from Malaysia owning one JDM VX. Have spent years to fix my VX.
Few months ago, I found VX lifter and Motor in China. Fix it onto my car last week. Run it smoothly.
I also manage to get a windscreen at China. This is surprising me. As I know there are very limited VX in China.....less than hundred. Don't understand Why the dealer still keeping the part![]()
I am having problems now as neither window will work, I did the widening of the channel years ago and they seemed to work ok. When I tried today nothing worked I've removed the door panels and re-lubed the rubber runners but they are both dead.
There seems to be an unusual looking 'block' in the fuse unit on the right hand side of mine which is a JDM should I look to replace that?
Both switches are dead and do nothing at the moment.
Should I stick a 12 volt supply into the electric motors to see if they function?
I remember now that the other day I did hear a clicking sound coming from the right hand side kick plate and have just removed it to find about three relays does anyone know what type they are and which one may be the window relay?
David,
I do know that the US version does have a relay behind the kick panel for the windows. Unfortunately, I've never had a problem with it so I can't help answer your questions. Others have had an issue with it so maybe you can find more info using the search function.
Here's one to get you started: http://www.vehicross.info/forums/sho...t=window+relay
Thanks most helpful.
Strange the passenger one worked on the motorway but refused to budge at home. The right hand side refuses to do anything.
