That part number refers to the length as well as the mounting sizes. The shocks aren't designed around a lifted height and are right around the same travel as the stock shocks. Old Man Emu carries the only direct fit shocks I know of that are built longer for a lift. Isuzu used a 3/4" stud on the bottom and a 9/16" bolt on the top. Matching the combo is tricky and Rancho only carries one direct fit shock.
I recently installed longer Rancho 9000xl shocks by converting the 3/4" stud to a 1/2" bolt. Then I was able to dig through Rancho's catalog to find the shock that fit my lift best.
Thank you, I will revisit the website and double check the Rancho part # but I was near certain on needing a size. May just have a mechanic deal with it.
