Results 1 to 15 of 31
Thread: installed Rancho 9000xls and a 1 1/2 lift. What a difference!!!
    Quote Originally Posted by djvx View Post
    Range VX or whoever can chime in---> Upon searching for these I found "Length choices" so with my lift being similar to yours I need to know that size info not just the part#, I think?
    That part number refers to the length as well as the mounting sizes. The shocks aren't designed around a lifted height and are right around the same travel as the stock shocks. Old Man Emu carries the only direct fit shocks I know of that are built longer for a lift. Isuzu used a 3/4" stud on the bottom and a 9/16" bolt on the top. Matching the combo is tricky and Rancho only carries one direct fit shock.
    I recently installed longer Rancho 9000xl shocks by converting the 3/4" stud to a 1/2" bolt. Then I was able to dig through Rancho's catalog to find the shock that fit my lift best.
    Jun 2008
    2001,black, vehicross 1353
    Thank you, I will revisit the website and double check the Rancho part # but I was near certain on needing a size. May just have a mechanic deal with it.
    Milwaukee WI
  1. Rancho 9000XLs replaced under warranty
    By Mile High VX in forum VX Talk...
    Last Post: 11/29/2014, 12:12 AM
  2. Rancho 9000XL's fitted what a difference
    By David Wiltshire in forum VX Talk...
    Last Post: 11/16/2013, 07:29 AM
  3. Lift installed.......finally!! OME 919
    By dsallade01 in forum VX Modifications...
    Last Post: 09/15/2013, 08:32 PM
  4. Help, please. Need Rancho & OME Lift Supporting Documentation
    By grober02 in forum VX Modifications...
    Last Post: 03/19/2007, 09:26 PM
  5. rancho c/u installed
    By Francesco Rizzo in forum VX Modifications...
    Last Post: 07/15/2006, 09:28 AM
