Results 16 to 30 of 31
Thread: installed Rancho 9000xls and a 1 1/2 lift. What a difference!!!
  1. #16
    Oct 2003
    2001, Foxfire VX,
    Thanks for the info. I'm primarily considering doing the Daystar springs... already have adjustable Rancho 9000x's (older models) and while minor ripples are better absorbed, the ride is still jouncy as h&ll due to bottoming out on the bumpstops.
    My VX practically SITS on its bumpstops, and especially the rear will jounce you HARD over small to medium bumps/dips in the road. I know you said here that the shocks make all the difference, but I have to wonder if getting your rig a little higher off the bumpstops isn't at least as accountable for the improved ride?
  2. #17
    Quote Originally Posted by a745035 View Post
    Many have trimmed the bottom section of the rear bump stop. I picked up a set from a salvage yard and did this so I still have my OEM ones. It made a difference in my ride for sure.
  3. #18
    Feb 2011
    2001, Kaiser Silver, VX, 0871
    Thumbs up Rancho 9000XL
    All Of You Were Correct. I Just Installed 4 New Rancho 9000XL Shocks To Replace My ORIGINAL OEM Factory KYB Isuzu Shocks. I Set The Front To 5 & The Rear To 4 As Suggested - MAJOR Improvement - That With the 4 New Toyo Versado Tires Because I Use My VX For Strictly New York Street Driving Only - NO Off Road Use !
  4. #19
    '01 Ebony #0939
    Quote Originally Posted by ALC1717 View Post
    What I'm Most Curious About Is How You Changed Your Keyboard Settings To Capitalize Every First Letter Of Every Word Automatically. I Just Tried It Manually And It's A Pain In The @ss.
  5. #20
    Feb 2011
  6. #21
    Sometimes my phone does that out of the blue...then it will change back on its own.
  7. #22
    Jun 2014
    99, silver, vehicross
    Who has lifted with the Rancho 9000xl 214's and 215's?
    Did you also use the ome 912 lift springs?
    Ome, skyjacker, and rancho have taller shocks available through independent 4x. What are the pros and con of doing it with oem size and taller shocks?
  8. #23
    Oct 2009
    2001 Mica Green VCS 0403
    How much did you have invested in all the parts, and where did you purchase them. I am planning on doing upgrades to my wifes VX this fall to include powder coating the stock rims and installing the largest tire possible with the same upgrade you completed.
    Thanks,
    Soggy
  9. #24
    Jun 2014
    2000, Ebony, 0570
    So these are suitable replacements, even though the stock shocks had resevoirs? I do understand that our shocks are 15 years old, but I don't put Rancho at the front of the line for new technology. Or is it more of a price savings comparison, as replacement resevoir shocks would run more than a grand?
  10. #25
    Jun 2007
    2001, Proton
    Actually
    I di the Ranchos because Sears had a sale and Rancho had a rebate.
    Carter Pewterschmidt
  11. #26
    Jun 2008
    2001,black, vehicross 1353
    Quote Originally Posted by Front_rangeVX View Post
    I don't think the lift had to much to do with the ride quality. the shocks made all the difference. There are specific models that fit the vx.
    Rancho 9000XL specs FRONT=
    RS999214
    Rancho 9000XL specs REAR =
    RS999215
    They can be found for around $100 each with some places giving deals for buying all 4.
    Range VX or whoever can chime in---> Upon searching for these I found "Length choices" so with my lift being similar to yours I need to know that size info not just the part#, I think?
    Milwaukee WI
  12. #27
    '01, Proton, VehiCROSS, 0229
    Thanked: 15
    I'm also putting on the Ranchos next week, I need it badly. After researching I think I also am going to do a small lift of 1" with the Daystars, instead of cutting the bump stops but I'm not sure what I'm looking for in regards to the Daystars.
    Can someone tell me a part number or point in the right direction for what I need for the rear Daystar 1" spacers?
    Ty
  13. #28
    Heya Tyler...
    Go here, its the thread I mentioned when we chatted on the phone this morning !! :-
    http://www.vehicross.info/forums/sho...913+experiment
    In the first post.. Gene talks about the 1.25 inch daystar...thats actually 1 inch.
    Give part #'s etc... all ya need to know.
    Jo
    Quote Originally Posted by djvx View Post
    That part number refers to the length as well as the mounting sizes. The shocks aren't designed around a lifted height and are right around the same travel as the stock shocks. Old Man Emu carries the only direct fit shocks I know of that are built longer for a lift. Isuzu used a 3/4" stud on the bottom and a 9/16" bolt on the top. Matching the combo is tricky and Rancho only carries one direct fit shock.
    I recently installed longer Rancho 9000xl shocks by converting the 3/4" stud to a 1/2" bolt. Then I was able to dig through Rancho's catalog to find the shock that fit my lift best.
  15. #30
    Nov 2013
    1999 silver vehicross 0427
    I run the adjustable ranch 9000 on my broncos, I love them. I will put these on Frankenstein also. The adjustability on these is great!
    Vehitrails
  1. Rancho 9000XLs replaced under warranty
    By Mile High VX in forum VX Talk...
    Last Post: 11/28/2014, 11:12 PM
  2. Rancho 9000XL's fitted what a difference
    By David Wiltshire in forum VX Talk...
    Last Post: 11/16/2013, 06:29 AM
  3. Lift installed.......finally!! OME 919
    By dsallade01 in forum VX Modifications...
    Last Post: 09/15/2013, 07:32 PM
  4. Help, please. Need Rancho & OME Lift Supporting Documentation
    By grober02 in forum VX Modifications...
    Last Post: 03/19/2007, 08:26 PM
  5. rancho c/u installed
    By Francesco Rizzo in forum VX Modifications...
    Last Post: 07/15/2006, 08:28 AM
