Results 16 to 30 of 31
Thread: installed Rancho 9000xls and a 1 1/2 lift. What a difference!!!
    Nov 2006
    1999 Blank VX #0101
    Thanks Front rangeVX for giving the EXACT part numbers for these Ranchos!!
    Nov 2006
    1999 Blank VX #0101
    New shocks way too soft? Something wrong? Ok, just had my mechanic install the Rancho shocks named above and we turned each adjustment all the way clockwise but these just bounce up and down about 3 times at every brake like bad shocks would... any suggestions?
    I got them off "Amazon /Just Suspension" for good price and got the rebate... they came very fast.
    Nov 2006
    1999 Blank VX #0101
    Rancho shock defect?
    I'm repeating this for effect... hahaha.
    '01 Ebony #0939
    Quote Originally Posted by disasterlady View Post
    Try the setting FrontRange mentioned in the first post. Rears at 4 and Fronts at 5. That will get you back to the feel of the stock suspension. After that, it's all personal preference.
    Nov 2006
    1999 Blank VX #0101
    Rancho RS9000XL adjustments
    Thanks for the info Y33TREKker...
    I think I found the problem.
    FYI to anyone else:
    The little adjustment knobs on mine seemed to slip and so when the guys turned them all the way to the 9 where I asked, they really didn't turn them. I took pliers as my girlie wrists are weak and turned them to max and they are much better now.
    Feb 2011
    2001, Kaiser Silver, VX, 0871
    Thumbs up Rancho 9000XL
    Oct 2003
    2001, Foxfire VX,
    Thanks for the info. I'm primarily considering doing the Daystar springs... already have adjustable Rancho 9000x's (older models) and while minor ripples are better absorbed, the ride is still jouncy as h&ll due to bottoming out on the bumpstops.
    My VX practically SITS on its bumpstops, and especially the rear will jounce you HARD over small to medium bumps/dips in the road. I know you said here that the shocks make all the difference, but I have to wonder if getting your rig a little higher off the bumpstops isn't at least as accountable for the improved ride?
    Quote Originally Posted by a745035 View Post
    Many have trimmed the bottom section of the rear bump stop. I picked up a set from a salvage yard and did this so I still have my OEM ones. It made a difference in my ride for sure.
    Feb 2011
    All Of You Were Correct. I Just Installed 4 New Rancho 9000XL Shocks To Replace My ORIGINAL OEM Factory KYB Isuzu Shocks. I Set The Front To 5 & The Rear To 4 As Suggested - MAJOR Improvement - That With the 4 New Toyo Versado Tires Because I Use My VX For Strictly New York Street Driving Only - NO Off Road Use !
    '01 Ebony #0939
    Quote Originally Posted by ALC1717 View Post
    What I'm Most Curious About Is How You Changed Your Keyboard Settings To Capitalize Every First Letter Of Every Word Automatically. I Just Tried It Manually And It's A Pain In The @ss.
    Quote Originally Posted by Y33TREKker View Post
    Sometimes my phone does that out of the blue...then it will change back on its own.
    Jun 2014
    99, silver, vehicross
    Who has lifted with the Rancho 9000xl 214's and 215's?
    Did you also use the ome 912 lift springs?
    Ome, skyjacker, and rancho have taller shocks available through independent 4x. What are the pros and con of doing it with oem size and taller shocks?
    Oct 2009
    2001 Mica Green VCS 0403
    How much did you have invested in all the parts, and where did you purchase them. I am planning on doing upgrades to my wifes VX this fall to include powder coating the stock rims and installing the largest tire possible with the same upgrade you completed.
    Thanks,
    Soggy
    Jun 2014
    2000, Ebony, 0570
    So these are suitable replacements, even though the stock shocks had resevoirs? I do understand that our shocks are 15 years old, but I don't put Rancho at the front of the line for new technology. Or is it more of a price savings comparison, as replacement resevoir shocks would run more than a grand?
    Jun 2007
    2001, Proton
    Actually
    I di the Ranchos because Sears had a sale and Rancho had a rebate.
    Carter Pewterschmidt
  1. Rancho 9000XLs replaced under warranty
    By Mile High VX in forum VX Talk...
    Last Post: 11/28/2014, 11:12 PM
  2. Rancho 9000XL's fitted what a difference
    By David Wiltshire in forum VX Talk...
    Last Post: 11/16/2013, 06:29 AM
  3. Lift installed.......finally!! OME 919
    By dsallade01 in forum VX Modifications...
    Last Post: 09/15/2013, 07:32 PM
  4. Help, please. Need Rancho & OME Lift Supporting Documentation
    By grober02 in forum VX Modifications...
    Last Post: 03/19/2007, 08:26 PM
  5. rancho c/u installed
    By Francesco Rizzo in forum VX Modifications...
    Last Post: 07/15/2006, 08:28 AM
