Results 16 to 30 of 31
Thread: CV Boot Replacement Plan - Correct me where I am wrong
  1. #16
    Tom...no need to seperate ball joints. You just remove the 4 bolts that mount it to the control arm. Much easier.
    Yah, I didn't learn that trick till after I'd done it the last time.
  2. #17
    1999, Ebony Black, VX, 1614
    I am working on this now and cannot seem to get the ball joint bracket over the lower control arm. What am I doing wrong?
    Help!
  3. #18
    2001, Ebony Black, 1153
    It must come down before clearing lower control arm. If your upper control arm will not come down low enough if you have a spare jack you can raise the lower control arm slightly. I am sure you can figure it out though. Just pull the ball joint plate thing down and rotate it diagonally slightly.
  4. #19
    I bought boots at my local Napa and they seemed fine. I recommend getting the CV boot clamp tool, makes things a lot easier, like $30.
    X2.
    An extra jack under the LCA - then wiggle, curse, pull, shove ...
    Actually it's not that bad once you lift up on the LCA with the extra jack.
  6. #21
    Thank you both for your replies. I did get past that point only to run into more trouble.
    I finally got everything removed, cleaned and ready for re-assembly and as I was putting my outer boot on and burping out the air, I see that there is a small tear in the brand new dorman boot that I bought. So my VX is currently sitting on a jack stand and I am going to have to get another new boot. I wont return the other one until I get something to replace it. Its currently keeping the outer CV clean.
    In the process, I came across a few items that I had questions about.
    1. one of the ball bearings from the inner CV fell on the garage floor. Should I be too concerned about damage? It looks fine.
    2. When the ball joint was resting on the lower control arm, some of the lubricant/greese from the ball joint was forced out of the bottom. Is that a problem?
    3. When repacking the grease back into the inner CV, do I just put a glob in there and then put the CV back in, then pack more grease in?
    Thank you to everyone for your help.
    Hopefully this CV saga will end and I will have enough knowledge to make this quicker/easier the second time around.
  7. #22
    WooHoo. Ain't it funner-n-innythang.
    Bummer. Mebbe you can patch it with some RTV & keep as a spare. Where was the tear?
    Nope. They are hardened steel. Yer good.
    Should be OK.
    That's perzakly what I did.
    It's what we do.
    Hope you don't have to.
  8. #23
    Thanks Tom. The tear was close to the large side of the boot. The tear wasnt all the way through. It actually looked like a flaw in the manufacturing, but I definitely wasnt about to assemble everything only to redo the process in a week.
    I am going to try the NAPA boot. From some reading on a few "high lift" forums, they say they are pretty meaty. Figure they cant be any worse than not working. Plus Bart said they worked fine for him.
  9. #24
    If the tear is under the band, then it'll be fine. I agree though that it'd be safer to get a new one.
  10. #25
    Update:
    I got the new boots from Napa. They were MUCH beefier than the dorman ones. They appear downright OEM(ish).
    I got both the outer and inner since the quality seemed better, I am going to replace both, but save my inner as a spare.
    I have one new question though, the NAPA inner boot (separate part number) contains a larger bag of green grease. Seems less "greasy" in the bag than the black smaller bag for the outer, but maybe I am wrong. Its a larger area to fill with grease though.
    Can I just use any old "CV Grease" in the inner and not worry about it?
    EDIT:
    Reading some "googles" looks like green might be better....Hopefully I dont booger it up.
  11. #26
    IIRC, I just put the provided pouches away & used synthetic axle grease instead.
  12. #27
    I completed my passenger side CVBoot swap last night. I have yet to take it for a test drive, but everything seems okay based on visual inspection alone.
    During said visual inspection, I did a compare against my driver side to make sure I didnt forget anything and realized that my driver side boot is very very worn and appears to be on its way to splits-ville. I will be replacing those boots in the next couple days.
    I have no road experience with them, but after holding an OEM, Dorman, and NAPA CV Boot in my hand, I can tell you that the NAPA feels the most heavy duty. Feels like they could take some hits without breaking.
  13. #28
    Now that you've done it once the next one will be a breeze. Should be a 2 hour job
  14. #29
    ... but after holding an OEM, Dorman, and NAPA CV Boot in my hand, I can tell you that the NAPA feels the most heavy duty. Feels like they could take some hits without breaking.
    Yah, I'd posted this pic a long time ago (L-R: AutoZone, MechaTech, Dorman):
  15. #30
    Wouldnt that be nice.
  1. can anyone tell me if this is the correct part?
    By VehiTONY in forum VX Troubleshooting...
    Last Post: 04/27/2014, 01:27 PM
  2. CV Boot Replacement - Problems removing control arm bolts
    Last Post: 01/06/2014, 05:38 PM
  3. If you plan on an ARB for the rear of your VX...
    Last Post: 11/11/2009, 11:17 AM
  4. CV Boot Replacement...or how to save $1600!!!!
    By Triathlete in forum General Tips...
    Last Post: 01/12/2009, 02:34 PM
  5. Correct storage bin p/n to replace changer?
    By Tone in forum VX Modifications...
    Last Post: 03/14/2005, 05:24 PM
