Results 1 to 7 of 7
Thread: front brake caliper test question
Threaded View
    2001, Dragon Green, 1342
    Okay, didn't pay close enough attention. Reinstalling front brake caliper. The 2 slide bolts are different, and sure enough, the manual says a difference. one is called a lock bolt (bottom) and the top is called a guide bolt. There is a difference between them. One looks like a regular bolt if you like with flats on the shaft, but the other has a different end, like a rubber tip. anyone know which is which
  1. Brake caliper assembly - extra rubber part?
    By atilla_the_fun in forum VX Troubleshooting...
    Last Post: 06/06/2012, 09:41 AM
  2. How do I replace the front brake rotors?
    By VehiGAZ in forum VX Talk...
    Last Post: 01/10/2009, 10:59 AM
  3. Brake Caliper Lock Washers
    By Jolly Roger VX'er in forum General Tips...
    Last Post: 02/20/2005, 06:30 PM
  4. Custom Brake Caliper Paint
    By Moncha in forum VX Modifications...
    Last Post: 08/16/2004, 05:38 AM
  5. Brake fluid question
    Last Post: 04/15/2004, 10:28 PM
