Results 1 to 7 of 7
Thread: front brake caliper test question
    2001, Dragon Green, 1342
    Okay, didn't pay close enough attention. Reinstalling front brake caliper. The 2 slide bolts are different, and sure enough, the manual says a difference. one is called a lock bolt (bottom) and the top is called a guide bolt. There is a difference between them. One looks like a regular bolt if you like with flats on the shaft, but the other has a different end, like a rubber tip. anyone know which is which
    did I answer my own question?
    Did a search, found a thread I did back in 06 that talks about the rear caliper. There (if it had been reinstalled correctly to began with) showed the bolt without the rubber end on the top, yet on a internet search for a different vehicle but same looking bolts, it is on the top. Sure glad I don't have to go anywhere today.
    okay, confirmed, rubber tippy goes on the bottom according to thread on Planet Isuzu.
    Re: Brake caliper pin orientation & piston condition w/photo
    Okay, so the guide pin is the one with the machined flats and goes into the upper ... advice on replacing them. Next question is are replacement caliper pistons available? Guess I'll do a google search. Thanks ...
    Glad you found the answer. Are you replacing the entire caliper or trying to rebuild it? I know some on here have found replacement calipers.
    No, nothing like that. Just needed to redo the shim grease from the cv boot change I just did. It seemed to be rather noisy. Had all 4 calipers replaced at Les Schwab before moving away from Washington.
    so has your stress fracture totally healed?
    Stress fracture is healed and back to normal. First race in 10 days.
    I thought the head of each one was marked, one had a "G" on it.
  1. Brake caliper assembly - extra rubber part?
    By atilla_the_fun in forum VX Troubleshooting...
    Last Post: 06/06/2012, 09:41 AM
  2. How do I replace the front brake rotors?
    By VehiGAZ in forum VX Talk...
    Last Post: 01/10/2009, 10:59 AM
  3. Brake Caliper Lock Washers
    By Jolly Roger VX'er in forum General Tips...
    Last Post: 02/20/2005, 06:30 PM
  4. Custom Brake Caliper Paint
    By Moncha in forum VX Modifications...
    Last Post: 08/16/2004, 05:38 AM
  5. Brake fluid question
    Last Post: 04/15/2004, 10:28 PM
