Results 1 to 4 of 4
Thread: E. Brake Issue?
    The ebrake and regular brales are two different beasts. The ebrake is a drum brake within the hump in the center of the rotor where as the brakes are the disc. Several people have had the calipers stick amd had to replace them. If it is your ebrake dragging they can be adjusted through a small hole on the rear of the backing plate uaing a screwdriver.
    I've got a sticking rear caliper (passenger side). It eats inner pads for breakfast. I've noticed that the piston is very hard to compress but the slide pins are moving properly. Each time I replace the pad, I exercise the piston 3-4 times for the full travel. It helps for a while but ends up sticking again within a few weeks.
    I'm just trying to nurse it along till I can replace all four calipers, rotors, & upgrade to SS lines this spring.
  1. brake issue
    By dndeans in forum VX Troubleshooting...
    Last Post: 02/10/2014, 09:52 AM
    Last Post: 12/14/2011, 01:15 PM
  3. uh oh, First issue with VX
    By H3_VX in forum VX Troubleshooting...
    Last Post: 08/16/2011, 01:39 PM
  4. Am I the only one??? Brake related issue...
    By VXD959 in forum VX Talk...
    Last Post: 09/08/2007, 06:39 PM
  5. Possible rod issue
    By Spike in forum VX Troubleshooting...
    Last Post: 03/08/2005, 07:58 PM
