Results 1 to 6 of 6
Thread: After market vs. OEM Idle Air Control Valve
    Oct 2013
    1999, Black, VX 1185
    Intermittent high idle - have replaced TPS, IAC, had the manifold cleaned, replace EGR...then had a mechanic tell me that he has had problems with aftermarket IAC valves on the Isuzu engine, and after replacing with an OEM, problem solved. Any similar experiences? Just checking before I spend the $75 on the factory part
    2001, Ebony Black, 1153
    Yes. for whatever reason OEM on IAC is the only way to go. I have also exprienced minor problems with after market MAF's so I would not try that one either, but I am sure others have been ok there. But for IAC I would go OEM only.
    How many miles? Any other problems?
    Mar 2012
    sold
    where to get the oem part? i replaced my iac valve about a year ago and i think its slightly malfunctioning - it was an aftermarket for about $30 iirc
    Oct 2013
    IAC Valve is available from ISUZU parts website for about $75. And as far as problems, other than some small minor oil leaks, it's running great. Has about 160,000 miles, and I just had the transmission rebuilt. I have owned it for about a year, and it's a lot of fun. Nothing better on ice and snow.
    Mar 2012
    sold
    Quote Originally Posted by JWJohns View Post
    when did you order? i was under the impression we could no longer order parts directly from isuzu as of late last year?...
    Oct 2013
    http://www.isuzupartscenter.com/
    Ordered yesterday, had a reply right away. Tried ordering the utility tray for the dash that is referenced on this site, but it is no longer available.
  1. Fast idle, low idle, (stalling) temp gauge all over the place.
    By Nikad92397 in forum VX Troubleshooting...
    Last Post: 11/07/2016, 08:48 PM
  2. Has The VX Market Gone Soft?
    By fotomaker in forum VX Talk...
    Last Post: 07/29/2012, 12:57 PM
  3. Odd Idle Control Problem
    By WebbRacing.com in forum VX Troubleshooting...
    Last Post: 06/17/2011, 01:29 PM
  4. Idle control valve
    By Offroad vx in forum VX Troubleshooting...
    Last Post: 03/23/2009, 08:11 AM
  5. where is PCV valve located, and how do i clean the valve tube?
    By CoastieCosta567 in forum General Tips...
    Last Post: 05/14/2007, 09:33 AM
