Results 1 to 4 of 4
Thread: Strange turn signal behavior
    Oct 2012
    2001, Proton, 0586
    I searched, but couldn't find this problem. My left turn signal started acting up: if lights are off, whenever turn signal goes on, so do ALL the "parking lights" (including dash lights). If I turn on the lights, the left turn signal turns on and stays on (activating it with the switch does nothing).
    Does this describe any known problem? If not, I suspect that one of the PO's half-assed trailer plug wires might have a short somewhere and causing this.
    I would start with the trailer wiring. If nothing found there check the wire bundle near the headlights. It passes through a bulkhead and has been k.own to wear and short out giving all kinds of strange symthoms. Good luck.
    .wiring can be a nightmare.
    Oct 2012
    2001, Proton, 0586
    I am tempted to remove and the poorly done trailer wiring and replace it with properly done wiring. Was there ever an OEM solution? Perhaps a plug that is left over from the Trooper days?
    Oct 2012
    2001, Proton, 0586
    Update, I disconnected the wires at left rear tail light (a bunch of vimpire clips) and problem is solved.
    Funny coinsedence, while searching for this problem I found PO of my VX asking a realated question: http://www.vehicross.info/forums/showthread.php?t=11513
  1. turn signal wire
    Last Post: 10/26/2015, 07:04 AM
  2. turn signal relay ??
    By orion in forum VX Troubleshooting...
    Last Post: 07/13/2014, 10:23 AM
  3. turn signal help
    By dsallade01 in forum VX Troubleshooting...
    Last Post: 06/28/2011, 08:44 AM
  4. turn signal problem
    By hemicross in forum VX Troubleshooting...
    Last Post: 02/10/2009, 01:29 PM
  5. Water in turn signal.
    By tomcat837 in forum VX Troubleshooting...
    Last Post: 04/18/2004, 08:33 AM
