Results 1 to 15 of 39
Thread: How far can i lift suspension? how big tires can i fit?
    Feb 2014
    1997 Silver VehiCross JDM
    OK, so i did a little testing today. not bothered with the spring spacers on the back. it seems to be lifted enough and the front has had the torsion bars wound down last weekend. The backs went on fine. the fronts rubbed some so i trimmed a bit of plastic and cut a bit of the metal out of the rear of the front arch. The right side is done new with enough clearance for full lock. The left side will be done tomorrow. then im having a 4 wheel laser alignment, then im going out to play.
    Pictures so far...
    https://dl.dropboxusercontent.com/u/...2015.38.33.jpg
    https://dl.dropboxusercontent.com/u/...2017.45.01.jpg
    https://dl.dropboxusercontent.com/u/...2017.45.15.jpg
    https://dl.dropboxusercontent.com/u/...2017.50.22.jpg
    https://dl.dropboxusercontent.com/u/...2017.50.47.jpg
    so far so good.
    Cool..Looks good...
    ...but FYI, under compression / off road...more trimming may be required...
    ...so be prepared for that!
    You can also see in pic 2 , the rear wheel is now sitting forward in the arch...
    .... if this becomes an issue, adjustable rear links from Indy 4x4 are the cure!
    Jo
  1. '99 VX tires... how big can i go without a lift?
    By mike nomy in forum VX Modifications...
    Last Post: 09/07/2010, 08:01 PM
  2. My maxed out suspension lift :)
    Last Post: 03/11/2010, 07:30 AM
  3. Calmini 3" Suspension Lift
    By TimG in forum VX Modifications...
    Last Post: 09/08/2009, 01:27 PM
  4. New Tires and lift?
    By Pigpen in forum VX Modifications...
    Last Post: 03/18/2005, 05:55 PM
  5. Lift and Tires
    By joesvx in forum VX Modifications...
    Last Post: 10/13/2003, 06:42 PM
