Results 1 to 15 of 39
Thread: How far can i lift suspension? how big tires can i fit?
    Feb 2014
    1997 Silver VehiCross JDM
    OK, update. i have 3" spring spacers on order and i pick up a set of 5 Maxxis Creepy Crawler 35x12.5x16 on 0 Offset steel modulars on Tuesday (2nd hand ebay bargain).
    Obviously i need a fair bit of lift for the 35" crawlers, having chunky side lugs and all but will i have to trim the cladding? if so can i just chop it away where it rubs or is there anything specific i can do to keep the trimming down to a minimum?
    Gonna have to put a roof rack on o keep my spare 35x12.5 wheel! maybe put a nice 12" sub in the rear door card in place of the space saver!
    Pics to follow
    You will need some....
    Front
    YES!
    Certainly a fair bit at BOTTOM back of front arches...
    Remove lower ARCH LINER ( OR CUT IT, I DID)..Cut away some of metal .. hammer back etc.. ..re-cover with arch liner......
    ...nothing structural under there. Small 'not required' pressed metal cross brace.. mines gone..no issues.
    Pics in my gallery
    AND.. some of lower lip of front cladding.. bit by bit till you do enough IMO!
    It'll rub more on sharp turns.
    Back
    Shouldnt need any, though your wheels will rotate fwd a bit given lift.
    A few of us with 35's have fitted adjustable rear links in order to center wheels again...
    ...plus lengthened the rear drive shaft to restore spline depth in yolk.
    Hope this helps.. holla if ya need more.
    Jo
    with 0 offset rims, (OEM are +38) you'll have a fair amount of trimming just to fit those, plus what Jo said to fit the 35s.
    I put -2 rims and went 1" wider than OEM, so I had lots of trimming and to fit them.
  1. '99 VX tires... how big can i go without a lift?
    By mike nomy in forum VX Modifications...
    Last Post: 09/07/2010, 08:01 PM
  2. My maxed out suspension lift :)
    Last Post: 03/11/2010, 07:30 AM
  3. Calmini 3" Suspension Lift
    By TimG in forum VX Modifications...
    Last Post: 09/08/2009, 01:27 PM
  4. New Tires and lift?
    By Pigpen in forum VX Modifications...
    Last Post: 03/18/2005, 05:55 PM
  5. Lift and Tires
    By joesvx in forum VX Modifications...
    Last Post: 10/13/2003, 06:42 PM
