If none of Jo's suggestions fix it, check the upper and lower control arm bushings and the ball joints.
 'Zoid
						'Zoid
						ok, i checked the tyre pressure. one was 10 psi the other was 40! that a side. i think i will have them all balanced and the laser wheel alignment done. hope that helps as it looks bloody good!
 'Zoid
						'Zoid
						oh, and whilst i was at it, i carbon wrapped my hood insert...
https://dl.dropboxusercontent.com/u/...2015.22.15.jpg
https://dl.dropboxusercontent.com/u/...2015.58.29.jpg
https://dl.dropboxusercontent.com/u/...2015.58.40.jpg
https://dl.dropboxusercontent.com/u/...2015.59.23.jpg
looks good on the car. photo to follow
 'Zoid
						'Zoid
						there is a bit of play in the front wheel bearing. Is this as specific VX part or is it the same as a Trooper part? bear in mind i have a JDM.
anyone got a part number?
 Super VXer
						Super VXer
						While you are looking for replacement bearings, you can tighten the hub nut to decrease the play on that bearing.
 'Zoid
						'Zoid
						where is the hub nut? under the freewhel hub cover?
 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						Yes. There should be a retainer with 3 little phillips head screws under the hub cover (or locking hub if you have them installed). Once that's removed, you can tighten the hub nut enough to load the bearings but still allow the retainer to be re-installed. Just don't tighten it too much or you'll add drag to that wheel.
I know that sounds confusing but I can picture it in my mind since I've done it before. There's a write-up with pictures for re-packing your bearings. Hopefully it's still available in the download section. If not, lemme know & I can post my copy.
Also note that those 3 little phillips head screws are a real PITA & it's easy to strip the heads. An impact driver will probably be needed. I replaced mine with allen pan head screws.
 Super VXer
						Super VXer
						rocky road supersliders - i just got a set a few months back they look great - like they should have came on the car
http://www.rocky-road.com/index2.html
make sure you ask for super sliders not rock sliders if you want the ones that stick out
