Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Brake Upgrades
  1. #16
    Nov 2007
    1997 SILVER
    My brakes are OEM standard with working ABS.
    On dry sealed roads I can make the tyres chirp and the ABS work from above 60 MPH.
    On gravel roads the tyres alternate skid / rotate / skid as the ABS works harder.
    My pedal goes nearly to the floor to achieve this, and I don't like it. I would like to see the brakes come on with less pedal travel. Putting larger, or 2 spot, calipers on will only increase pedal travel unless you also update the master cylinder.
    PK
  2. #17
    Oct 2012
    2001, Proton, 0586
    I find my stock brakes very mediocre...
    But this thread is more auto HOW to upgrade the brakes, rather than WHY
    96 Eclipse Spyder GSX (already turbo, AWD swap)
    93 Eagle Summit AWD (4G63 turbo swaps)
  3. #18
    01, LineX tan/black, 1055
    Quote Originally Posted by Etfren View Post
    Isn't braking ability ultimately limited by tire grip though? If you have enough grab to lock up the tires, you have maxed out your braking ability and then tires become your limiting factor in stopping. Feel free to correct me if I am wrong, I am very interested in this.
    I can get my wheels locked up with the EBC greenstuff pads and R1 rotors just fine. Granted I am on 35" soft compound MT/R Kevlars, which aren't exactly made for good pavement stopping power.
    Same setup I have, ABS disabled, no way I am locking up anything, even with the pedal pressed as hard as I can. I will be replacing the the master cylinder next, not much left after that.
  1. Recommend Me Some Overland Upgrades
    By Ala5ka in forum VX Modifications...
    Last Post: 04/30/2014, 09:30 AM
  2. Lights, Paint & Upgrades, OH MY!
    By MiamiIronman in forum VX Modifications...
    Last Post: 02/16/2012, 08:03 PM
  3. upgrades for 4L30E?
    By AlaskaVX in forum VX Modifications...
    Last Post: 10/13/2005, 05:20 PM
  4. Sound system upgrades...
    By Dallas4u in forum VX Modifications...
    Last Post: 02/12/2004, 04:13 PM
  5. Best Upgrades for Performance/Mileage
    By On Your Left in forum VX Modifications...
    Last Post: 11/29/2003, 01:16 AM
