I am trying to program a key fob for my JDM. However I can't find the green button. The instructions below say the button is on a box above the LH kick panel, however I can't find it. Is the JDM alarm box on the lefthand or right handside of the car? Any assistance in locating the elusive green button on a JDM would be appreciated.
VEHICROSS: 99-01
1. ACCESS THE PROGRAMMING BUTTON (GREEN BUTTON) ON THE REMOTE ALARM CENTRAL LOCKING CONTROL MODULE LOCATED ABOVE THE LH KICK PANEL
2. TURN IGNTION TO ON
3. PUSH & HOLD THE PROGRAMMING BUTTON FOR 2 SECONDS
4. THE RED SYSTEM WARNING LAMP WILL ILLUMINATE FOR 5 SECONDS (although mine doesn't work at all)
5. WHILE THE SYSTEM WARNING LAMP IS LIT UP:
- PRESS & HOLD THE REMOTE LOCK & UNLOCK BUTTON
6. THE WARNING LAMP WILL EXTINGUISH
7. AN ACOUSTIC SOUND IS EMITTED ONCE AND THE PARKING LAMPS WILL FLASH ONCE
8. TURN IGNITION SWITCH TO OFF
9. Confirm successful programming by locking and unlocking vehicle.
10. Repeat above procedure to program remaining remotes.
