Just FYI...
If you intend on using Dynomat for the Hood... do not also use the OEM Hood Blanket. I've voiced my concern on here before...AFTER I already installed everything...but I haven't tested it yet. After installing a new Rear View Mirror w/inside and outside temps and a sensor I had to mount, by the front grill... I also decided to add another sensor in the engine bay to monitor live engine bay temp. I haven't used it yet as we are yet again under some snow..but just by running the VX for about 15-20min in idle, and the hood down, but not latched all the way... you can tell it is to damn hot in there. I'll have to remove the OEM blanket.
Keep in mind that anywhere I applied Dynomat (Dynomat Extreme, the heaviest they make) .. I also added Dynaliner on top of the Dynomat. That's 3 layers in the engine bay... I have NO idea what I was thinking...
Moral of the story... Dynomat is a great substitute for a bad/worn/or no Hood Blanket. But don't use both at the same time.
When are we going to get some pics?
So what is the purpose. It seems that higher under hood temps is not a good trade-off.
