Results 1 to 10 of 10
Thread: Engine dying out (3 times)
    Nov 2003
    2001,Silver, Vehicross,0466
    Unhappy Engine dying out (3 times)
    I purchased my 2001 Vehicross and have experienced engine
    problems. Have you experienced this problem? What did you do?
    Lady Silver
    2001 Proton VX 0790
    More info please.
    Is the problem repeatable or tied to anything?
    Does it throw a check engine light?
    Only engine cold or hot?
    Dies at idle, onder WOT?
    You get the idea.
    John C.
    Yes, you need to give a more detailed description of the symptoms. Does it die when just idling? When the engine is cold or hot? In "park" or in "drive"? Does the idle or engine speed fluctuate wildly? When? Does the problem occur in "drive" when accellerating (mild or hard accelleration?)? In "drive" cruising? When coming to a stop? or a hard stop?
    '01 Ebony #0939
    I seriously hope that you aren't saying you've had three engines that have died (failed) on you. Even though it's bad enough, I hope the problem you're talking about is just the engine dying occasionally, because I'm sure the members of this board will be able to help you determine the cause (and solution) to your engines' problem.
    2000 Dragon Green VX 0485
    Re: Engine dying out (3 times)
    Lady Silver
    2001 VX If it's still under Warranty take it back to the Dealer.
    If not, ck your air filter & disconnect your battery & reconnect to reset computer parameters.
    Dragon Bob
    Feb 2003
    Dying problems....
    My VX does not want to start sometimes...it wants to die out on me. It tries to start but does not turn over...it just dies. Then if I hold the gas pedal down it will keep idled and will not die until I let off the gas pedal...then it dies.
    After awhile, it starts just fine
    1999, Silver, VX, 1412
    NOTHING BUT PROBLEMS
    Since I bought my VX in July with 32000 miles on it, I have had NOTHING but problems. The shocks have gone, the CD player has died, the DS window repeatedly leaves its track, the headlight rubbers have had to be glued back on, the engine must be cranked repeatedly to get it to start, then it smells like gas outside, and the whole vehicle creaks and rattles like a tin CAN. I would NEVER advise someone to buy this vehicle. I wish I hadn't.
    Why cut down the trees to build the church when you can just worship in the forest?
    Freon - sorry to hear of your complaints. How much would you take to be relieved of your rattle trap - I’m interested.
    As for the first subject of this thread, fuel filter, fuel filter or intake gaskets. Hopefully we’ll get more info.
    Aug 2003
    2001, proton yellow, VX, 1085
    Yup, agreed..... fuel filter indeed.
    Tone
    Tony, Unfortunately I owe about $15,500. It still has relatively low mileage, a warranty, and is in immaculate physical shape. Its going in for all the warranty work next week. I'll let you know how it comes out.
    Bill
  1. Scary times
    Last Post: 06/23/2010, 07:17 PM
  2. How many times to Moab?
    By cyronman in forum VX Talk...
    Last Post: 04/26/2007, 12:47 PM
  3. Supercharger 0-60 times?
    By Syntek VX in forum VX Talk...
    Last Post: 10/12/2005, 08:57 PM
  4. Engine dying while stopped?
    By JAFO in forum VX Troubleshooting...
    Last Post: 11/04/2004, 07:29 AM
  5. 1/4 mile track times
    Last Post: 05/20/2004, 03:12 AM
