From Fastenal. You can order and ship direct to store (or to your home for a little more $$). I labeled the pic itself with the part number for future reference.
Fastenal Part# 0171864
It's a Robertson Head, stainless 12x1" basically. I've searched and the best place to get the screws is Fastenal.
NOTE: I noticed that when I tried to screw them into some of the original grommets, that the grommets had deteriorated as they were the originals. Isuzu decided to use the most expensive type of grommet which comes with a small rubber seal around the plastic grommet so that it provides resistance to help keep it sturdy and to help protect the paint. I would suggest grabbing some new grommets as well, that is... if you notice they are loose OR the rubber around the base is deteriorated or gone.
There are many cheapies out there, but they won't have the rubber seal. These are an exact match to OEM except they are 2mm longer, which is better. Just google Auveco 21324 and you can find them online. They come in boxes of 15. Fastenal can order them, but they will likely be MORE expensive (maybe even double price).
I've shopped at both of these places and are very nice to go to for things like this. I've also used an eBay store (forgot the name) that also has this kind of grommet stuff...try these...
http://shopsite.hypermart.net/ss11.2...&Search.y=-363
http://www.thecliplink.com/auveco-ca...w-grommet.html
