Results 1 to 8 of 8
Thread: Engine shuts down
    May 2003
    Wink
    If the above post doesn't help...check the ground terminal under the dash IIRC on the passenger side under the kick-panel. There was a TSB that said the ground screw can come loose and cause electrical issues. I had the problem myself after about a year of ownership.
    Also check the electrical harness that runs under the driver-side headlight as others can chime in about the affects of a chafed harness.
    Good luck.
  2. Vx Engine
    Last Post: 02/21/2006, 04:53 AM
  3. Replies: 1
    Last Post: 03/15/2004, 11:02 PM
  5. Engine starts then shuts off
    By deldorado in forum VX Troubleshooting...
    Last Post: 05/07/2003, 02:08 PM
