I originally post in the new members area and it was suggested to move it here. Hopefully this is the right place. Sorry I am new to forums in general. Thanks in advance.
Hey guys, my name is Tobias from Ohio. I dont have a Vehicross but I have a 2002 Axiom. It has been super reliable up until Sept of this year when my TOD light started flashing. I only have about 80k miles on it. Always taken good care of it. No pulling trailers or abuse, just easy street driving and drove to Florida couple times from Ohio. I started digging around and found this site. You guys have the best info out there anywhere that is accurate and helpful. So I decided to join the forum, and glad I did.
Question I have is, where can I get the transfer case front and rear speed sensors? I have manually pulled the codes per the info provided in the forums and found the codes indicating front and rear speed sensors. Just for the sake of elimination, I replaced the TOD selector switch in the left side dash and replaced the vehicle speed sensor in the trasfer case. No luck. I decided to investigate the front and rear speed sensors to see I could remove and clean them off and reinstall to check but managed to damage the plastic piece that holds them in the housing, now I need to replace them. They appear to be part of a wire harness on the transfer case and not replaceable individually.
Any help would be great. I am kinda stuck.
I know this isn't what you wanted to hear, but if it is a sensor problem, its not gonna be cheap to fix unless you hit up the salvage yards, and axioms are few and far between. Good luck, I have been without TOD for a while, no problems!
