Here's what I was able to check so far. I squeezed the CV boots like I was a teenager getting to second base for the first time and felt nothing out of the norm (no loose part in there). I did as PK advised and jacked up one tire at a time. I turned each tire and saw the CV axle turning on each one and also each one turning the front drive shaft. I shook and twisted the front drive shaft by hand and got almost no movement (so that's good too). While I was under there, I also his the U-joint and other grease points. The only thing I wasn't able to do was drain and refil the T-case fluid. I don't have a pump or anything handy to gravity fill it. Later tonight I am going to try filling it with a squeezeball pump from the gas line on an outboard (yes, of course I will make sure it's dry first) and see how that goes. Any other ideas?
