Results 1 to 3 of 3
Thread: Oxygen Sensor
    Dec 2011
    2001, white, ironman, 0431
    Oxygen Sensor
    Are the EGR and Oxygen Sensor related ?
    2001, Proton Yellow, #0580
    Only in that they both measure various levels of gasses in the system and feedback into the ECU. The EGR mounts at the top-back of the engine. The O2 sensors are on the exhaust under the VX...
    Aug 2005
    1999, silver, 0887
    If you get a 401code for bad EGR you will likely get a message saying the 02 sensors are bad/dirty. Clean the EGR tube and maybe replace the valve itself. Then run some Lucas gas treatment for a while and maybe the 02 warnings will go away and turn off your CEL.
  1. Oxygen Sensors
    By blacksambo in forum VX Troubleshooting...
    Last Post: 11/04/2013, 08:52 AM
  2. Replies: 7
    Last Post: 03/12/2011, 06:29 AM
  3. Oxygen Sensor Removal
    Last Post: 01/20/2010, 07:42 AM
  4. O2 Sensor/Coolant Temperature Sensor
    Last Post: 04/21/2007, 01:50 AM
  5. Oxygen Sensor
    By XCross69 in forum VX Talk...
    Last Post: 12/09/2006, 04:57 PM
