On the front passenger side of the engine there are two metal that turn to rubber lines that run across from the engine to up by the radiator. Are those just engine oil lines that run up to by the oil filter I haven't had a chance to really look at them yet. If so what size rubber tubing is that. Just at a peek I know they are starting to leak pretty good at the ends. Thanks in advance.
