Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 54
Thread: Rotella Trials
    I've been running the Rotella T6 for a while now. IMO, it burns just as much oil. I wouldn't say more than before, but definitely about the same.
    Dang. There you go pissing on my charcoal again ... & I had such high hopes for the magic elixer.
    2000 IronMan #11
    Maybe, just maybe, the secret equation is 1 gallon T6 and 1 Quart Mystery Marvel
    1999, Ebony Black, VX, 1614
    Or its just the 1 quart marvel mystery oil.
    So how is Marvel different from Seafoam? I seem to remember a recommendation from someone (or maybe it's even on the Seamfoam package) to only add the detergent in the last X many miles before an oil change. Agree that you're cleaning the gunk if you put it in at the oil change, but where is that gunk going over the 3-5K miles between changes? Is it just clogging your oil filter that much faster?
    Feb 2013
    2001, Green, Vehicross, 0773
    If I recall you add the seafoam before an oil change because it slowly deteriorates your oils ability to lubricate parts. It helps lossen up deposits that would otherwise not move between your 3-5k mile oil change.
    '01 Ebony #0939
    I've read the same thing about using fuel system cleaners like the stuff from Chevron with Techron. You run something like that in the last tankful of gas before oil change time for the exact reason you stated.
    Quote Originally Posted by Y33TREKker View Post
    ....am I crazy...or just missing somthing. What does it matter if you add the fuel additive before or after an oil change? They dont mix.
    '01 Ebony #0939
    Because particles from deposits that get broken up or dissolved in your intake passages when using a fuel system cleaner can end up in your crankcase via blowby since that mixture ends up in the combustion chamber/engine cylinder.
    You can obviously add a fuel additive whenever you want, it just makes more sense to do so in your last tank full of gas before an oil change so that any deposits that get broken up get later removed when the oil filter is changed, and better to remove those deposits at that time rather than leave them in the filter to contaminate new oil.
    2000 IronMan #11
    Im changing the next couple at 1.5k.
    Aug 2005
    1999, silver, 0887
    We use Marvel and Mobil1 continuously to curb oil use. Please make sure your EGR system is clean, also. It affects oil use if plugged.
    Oct 2003
    1995 Isuzu Trooper LS
    Seafoam is basically a solvent...you don't want to run it very long with that in there.
    Mar 2012
    sold
    im willing to try anything - quarts of marvel, cans of seafoam, nothing works on mine so far - and ive stuck with them for months
    id say i use a gallon inbetween oil changes - disgusting.
    Just out of curiosity, have you cleaned the EGR or replaced the pcv
    Mar 2012
    sold
    i clean my pcv with carb cleaner every week or so - never took the egr off to look at it closely - how would i know if it was messed up and how might one go about cleaning that sucker?
    '01 Ebony #0939
    Almost sounds like it'd be worth trying a method similar to an overnight soak in a parts bath. If Seafoam is basically kerosene, I wonder what would happen if a person drained the oil, removed all the spark plugs, and just filled the cylinders with kerosene to give the rings a chance to actually soak rather than just be subjected to a mixture of oil and Seafoam?
    Or to take that even a step further, I have no idea how much kerosene would be necessary to achieve a fill level from the oil pan up high enough that all the rings in all the cylinders would actually be able to soak, or if that would even be enough since some parts still need to be scrubbed after an overnight soak, but if you're using a gallon of oil between changes, could it really make things any worse?
    I'd add a disclaimer though that I've never looked at a VX motor straight on to even eyeball how high a piston at TDC in a cylinder would be in relation to the rest of the motor, to get an idea where that high a level of kerosene would take kerosene in the rest of the motor when the fluid leveled out, so that kind of soak might take kerosene to parts of an engine where it shouldn't be.
  1. Ryan (Littlebeast) progress at Olympic trials
    Last Post: 06/24/2012, 12:10 PM
  2. Trials Trucks = BIG Fun
    By ZEUS in forum Chit-Chat ...
    Last Post: 12/23/2010, 07:06 AM
  3. Rotella by Shell
    By Gussie2000 in forum VX Talk...
    Last Post: 04/04/2010, 10:19 AM
  4. Little Beast olympic trials????
    Last Post: 07/01/2008, 12:21 PM
