Rolling down the freeway sunday coming back from Milwaukee to Madison (70miles) Check engine light comes on, check trans light starts flashing and the A/T Fluid Temp light come on as well, all simultaneously. I look in the rear view to check who's behind me so I can pull over and I see a cloud of smoke trailing me like I am a missile running down the freeway.
I look under the hood and all looks good and normal, I look under the passenger side and see the whole undercarriage from the beginning of the transmission all the way to the rear tire and shocks, everything covered in trans fluid and it is smoking off of the hot transmission casing.
Had the VX towed to the Isuzu service center in Madison, WI and they called me monday afternoon stating that my transmission has died with much noticeable internal damage due to age and if i should want to get it running again soon I should look at replacing with a used for $2,200 installed or a new OEM for $4,600 with 12mo 12,000mi warranty. Needless to say that is a lot of money to come up with without a notice. He also mentioned that rebuilt versions of our transmission are rarely successful and they have not had success ever when trying this in any VX or Trooper.
I'm going to tow her back to Ohio where my other Astral is located and put the two together, taking the best from each to make the ultimate machine.
155,900 miles on the tranny on its last go round and given the shortness of the drive in comparison to the 600 mile trips to Ohio every year I'm glad it did it before I decided to go back home for the holidays! I could have been stranded in Indiana or something… lol
