Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: Hood Drain Hole
    Oct 2012
    2001, Proton, 0586
    I never bothered re-installing my drains. I just do not see the point. Engine bay is open to elements.
    '01, Proton, VehiCROSS, 0229
    Thanked: 15
    Worse case scenario.... if you need a hood blankie and one cannot be obtained... you could always use Dynomat Extreme, Dynaliner (1/2" or 1/8") or both. It works great!
    Ty
    Oct 2012
    2001, Proton, 0586
    About that... I threw away my perfectly fine blanket... Seeing how you guys are crazy about those things, I should have saved and auctioned it off
    Aug 2008
    1999, Astral Silver, 1018
    It was raining today and after I got finished adding oil I noticed the bottom of the battery tray was swimming in water. The metal plate underneath that the battery sits on the paint has chipped and is rusting but today I looked down even further inside and the front frame bar between the battery and radiator is all covered in rust.
    Now I'm really getting concerned because it looks like because of the way the tube has been draining I'm going to end up with the front corner all rusted out. I pulled the tube out and turned it so it drains away from the battery but that isn't going to solve much of anything since it's so short. The drivers side hose/drain doesn't have any problem at all.
    Pulling out the drain tube won't solve anything, heck I don't even know right now if the water is even all going through the drain tube and not just coming out from under the insert. Is the only solution a longer drain tube like the fish tank air hose someone else suggested or is there another way to minimize any more damage?
    01, LineX tan/black, 1055
    Just LineX the entire hood and insert, then it doesn't matter if the water sits in there FWIW, I threw my blanket away along time ago, it got caked in red clay, wasn't worth messing with it. Seems to me it would keep more heat in the engine bay
  1. Hood Drain Tubes Installation
    Last Post: 05/17/2013, 08:05 AM
  2. Replacing oil drain plug
    By VX KAT in forum VX Talk...
    Last Post: 06/27/2009, 02:12 PM
  3. Radiator drain plug
    By Jonnie in forum VX Troubleshooting...
    Last Post: 03/24/2009, 10:12 PM
  4. Oil Drain Valve
    By Doc4h in forum VX Modifications...
    Last Post: 05/19/2005, 12:42 PM
  5. Oil Drain Plug Help
    By DeafVX in forum VX Talk...
    Last Post: 08/16/2003, 11:11 AM
