mine came like that too... I just pushed the bushings out use various washers/sockets... and a bench vice... re-installed them the correct way... just slows you down. You can send them back to rancho, but there may be a chance you get a new set with the same issue. I read NUMEROUS threads on a bunch of different forums as far as mounting them upside down, it was a 50/50 split pretty much, so i just decided to swap them myself.
