I would like to shut off the abs light on dashboard. I think deermagnet once wrote something on this but I couldn't find it.
Anyone recall how to do it?
Here's the one I wrote up.
thanks for quick reply
that's a pretty involved one, i thought i recalled seeing one that had to do with bending a pin down either on fuse or something.
By far the easiest and fastest solution is to put a tiny piece of Black Electrical Tape over the ABS light. Git 'er dun.
Can't find Mark's write up either. There are some pix in this thread though:
http://www.vehicross.info/forums/sho...hlight=ABS+pin
I think this is the thread you were looking for, but looks like Mark deleted the content (I'm guessing based on his "edit" date).
And the link to his write-up he attached in post #16 is also empty, but he does write some detail in that post.
http://www.vehicross.info/forums/showthread.php?t=12016
But, found another thread where he talks about how to remove it.
Posts # 17, and 22-25.
http://www.vehicross.info/forums/sho...=abs+light+pin
