Results 1 to 8 of 8
Thread: ABS and drive shaft U joints
    Sep 2013
    1999 Arctic Silver Vehicross 1325
    Wrench ABS and drive shaft U joints
    My ABS light is on it is registering codes 12 and 44.
    I think it is the ABS module.
    Does any one know where to find one or if another manufactures is compatible?
    Like Audi or Nissan?
    Also I wanted to change the drive shaft universal joints and while I think I found the front one no one seems to have the rear?
    Does any one have a solution to the U joint supply?
    Thanks for any help you all can give me.
    This is my first VX and I am finding out that parts are hard to find!
    Start reading this thread at about post #44. We've had lots of discussions on the ABS failure, and found a great option - Repair exisiting module with lifetime warranty for $49!!
    http://www.vehicross.info/forums/sho...bs+ebay&page=2
    In a nutshell - there's a company on ebay that rebuilds hundreds of these ABS units from all types of cars. Several VX owners have now used him and they work perfectly - - and have a lifetime gaurantee!!
    Here's the current ebay listing: (Doesn't matter that it says Trooper - he fixes the VX one under this too).
    http://www.ebay.com/itm/110784352777...84.m1438.l2649
    IIRC, some folks also found out that the ABS module from a Durango works on the VX too. The search function on the home page should help you find that thread.
    One of our members was looking into having the U joints on the drive shaft replaced with CV joints. Maybe contact LittleBeast to see what he found out.
    That's the thread link I attached above
    OK.
    I just assumed you pointed to the thread that discussed the ABS repair. My bad.
    OK.
    yer not bad T, yer jus a little slower than some…...
    sorry kitman…T4B and I just haffta mess with each other…sorry for the TJ.
    ... yer jus a little slower than some…...
    She spends her whole post talking about one solution & then includes a link to a different solution ... & I'm the slow one???
    That's just not right!!!
    Just so that I'm not accused of thread jacking though:
    One final solution is to just remove the ABS light. The ABS on our rigs is ... well ... less than optimal. I feel much safer with mine disabled.
    Sep 2013
    Thanks every one for your help I found a Trooper unit today and will install this weekend!
    Found a shop here that builds custom drive shafts for off roaders to go over my drive shaft.
    Forum is great everyone is very helpful lots of useful info.
  1. Front drive shaft
    Last Post: 02/17/2017, 07:02 PM
  2. Front drive shaft help
    By cheetah2390 in forum VX Troubleshooting...
    Last Post: 05/22/2014, 04:57 PM
  3. Front drive shaft in 2WD.
    By Dumke in forum VX Talk...
    Last Post: 05/02/2013, 06:16 PM
  4. Drive Shaft Rebuilding
    By blacksambo in forum VX Troubleshooting...
    Last Post: 12/03/2011, 11:27 PM
  5. Drive shaft problem
    By AU92 in forum VX Troubleshooting...
    Last Post: 10/12/2006, 06:48 PM
