Results 1 to 4 of 4
Thread: will not start . fuel issue.
    1999, Ebony Black, VX ,1976
    My brother now owns my old vx. he went through a puddle and now it will not start. it has power to the fuel relay but does not not get power from the pcm to turn on the relay to send power to the fuel pump. has anyone had this problem? have checked the fuses.
    1COOLVX
    Nov 2007
    1997 SILVER
    "went through a puddle and now it will not start."
    Hmmmm - how deep was the puddle?? Bonnet depth could be a real problem.
    If you hotwire the power to the fuel pump, will it start and run then??
    PK
    about 2 feet. yes it will run if bypassed. has to be a bad or loose connection.
    '01 Ebony #0939
    Think it could have anything to do with the Vehicle Speed Sensor or the electrical connectors near it getting wet? The VSS is located on the passenger side of the transfer case and there are a couple of electrical plugs right in that area. The VSS also provides one of the electrical inputs to the PCM.
    I know I'm not the only person here who's ever had those connectors get wet and had the engine start running very rough anyway. The time it happened to my VX was when I was driving in a very hard rain on the highway.
    The one's I'm talking about are near the rear passenger side of the transfer case, and for some reason I remember having to remove the transfer case support cross-member, so there may be another part of the wiring harness routed along the top of the cross member. I ended up drying the connectors, coating them with dielectric grease, and adding some heat-shrink tubing to try to waterproof them as good as I could, and haven't had any similar problems since then.
  1. Where to start?
    By dohvb1 in forum VX Troubleshooting...
    Last Post: 10/29/2012, 08:40 PM
  2. Help: How to Replace fuel lines going to the fuel rails.
    Last Post: 08/10/2012, 11:10 AM
  3. Fuel Injectors and Fuel Pump
    Last Post: 08/31/2004, 11:47 AM
  4. Help! Won't start
    By ISCE in forum VX Troubleshooting...
    Last Post: 12/14/2003, 03:20 PM
  5. HELP!!! Sometimes Won't Start
    By chumone in forum VX Troubleshooting...
    Last Post: 10/20/2003, 07:20 PM
