want to install an OPG, possibly on the column, more then likely someplace lower, anyhoo, question is: i mod'd a OPG on my bike, was kinda easy, just changed a bolt in the head and ran line up to gauge. what is needed to add a OPG on the VX?
I have the Oil Press Regulator an Air/Fuel, Boost & VAC, Water Temp and Voltmeter, Autometer Carbon Fiber Gages
We used a oil tap that screws in and has sending units off it.
-Dave
ok, screwed into what?
and do you have part numbers?
Dave, how did you get the water temp gauge to work? I have the same carbon gauge, but haven't had the nerve to tap into the engine yet! I would appreicate any help.
Thanks Dave,
Dave...
Oh Apostle, I also have an oil gauge. I just removed the top plug in the collar that the filter screws into, and relocated the stock oil sensor into the top hole. Then I tap the stock hole just a little to get the Autometer sensor to fit. The Autometer sensor is to big to fit into the top hole in the collar, so that's why I relocated the stock oil sensor. It's very easy to do and only take about 20 minutes.
Always a kid at heart!
The volt and and water are not hooked up yet... this week it is going back to finish install on them and some other goodies... will let you know as soon as she comes back.
-Dave
This is the very reason why I paid $75 to have it all done by a mechanic, heh.Originally posted by VXMAN
Oh Apostle, I also have an oil gauge. I just removed the top plug in the collar that the filter screws into, and relocated the stock oil sensor into the top hole. Then I tap the stock hole just a little to get the Autometer sensor to fit. The Autometer sensor is to big to fit into the top hole in the collar, so that's why I relocated the stock oil sensor. It's very easy to do and only take about 20 minutes.Saves me the time and trouble, and also insures me that if it goes bad, I call them up.
yeah, i dont have any taps so, looks like its going to a mechanic![]()
