Results 1 to 7 of 7
Thread: smells like gas
    Apr 2012
    2000 white ironman 0101
    smells like gas
    My vx smells like gas when idling. No one can figure out y. Have had all test done ie pressureisiizing the fuel system. Help
    Where does the smell appear to be coming from? Exhaust, engine bay, under the vx?
    Mar 2012
    sold
    mine did this when i first got it and right before i started having rough idle problems - changed the fuel pressure regulator, idle control valve, ant throttle position sensor and it all went away - not sure which one did the trick but it had to be one of the three
    Mar 2012
    2001,Ebony Black,VehiCross,0565
    Mine was a break in the EGR valve exhaust, and same for me, only smelled when idling.
    ...and you will know me from the trail of dust...
    The FPR is right below the vents below the windshield so I'm guessing that was the culpret.
    The other thing to consider is whether the tank was overfilled. Doesn't the overflow from the fuel fill go to a charcoal canister in the engine compartment?
    Apr 2012
    I can't tell. It smells every were around the car no performance issues though. Maybe loss of mpg. And thanks evil
    01, LineX tan/black, 1055
    I think that charcoal canister is just forward of the fill spout. Look up under the body, it is banded in place.
  1. Am I getting F'D by the dealer?? Smells fishy?
    Last Post: 12/23/2007, 12:49 PM
  2. Brake Smells?
    By Thejerseyfish in forum VX Troubleshooting...
    Last Post: 03/26/2007, 04:24 PM
