Quote Originally Posted by CatFish View Post
So you have less miles on the odometer than you have driven? Strange that the odometer does not count miles when the TOD is off.
Also, Tom's toad mode has the rear drive shaft disconnected which is why his odometer doesn't advance while being towed.
Yah, 'toad mode' = being towed (4 down).
I only pointed out the 0 miles accumulation on the ODO (when being towed) to stress the point that you should do both the TOD disconnect and the locking hubs for best results. It's all well and good to cut power going to the front but if the front end is still spinning, then you really aren't reaping the full benefits.
